Mac Mini / late 2014 / High Sierra 10.13.6
Roon / 1.8 / build 831
Core is hardwired / Wifi AirPort Extreme
Hardwired Roon Bridge / Allo DigiOne / SPIDIF to Dac
ChromeCast / Endpoint
iPad Air / Remote and endpoint
iPhone / same
Windows10 / Remote
27,000
Second time I caught the iPad on full volume, even with limits set as recommended with lock screen controls. I no longer put headphones on till this is checked, very dangerous!
Hi Danny,
Thanks for your reply.
No, I’m not using the iPad buttons to set full volumes. The usual iPad behaviour is that it remembers the last setting for its speakers and another setting for headphones. Plugging back into my headphones for a listen has blasted me with full 100 volume, before I even touch any controls. With this in mind I have no reason ever to set my headphones to 100. Aren’t volume limits supposed to prevent this?
I believe this has started when I enabled locked screen controls. I have many end points and have not been able to find out which combination would make the iPad go to full volume.
EDIT: I do have a few end points that are set to 100 max for A/V receiver, raspberry Pi, or Chromecast. Perhaps Lock Screen controls are mirroring these settings.
volume limits only impact how roon changes the volume. if the device is changing the volume underneath us, we can do nothing about that. Same goes for volume limits on a USB or Networked DAC that has a volume knob. The volume limits do not impact that knob – it’s only for the Roon UI (and lockscreen controls which in turn tell Roon to change the volume).
