ubiquiti Wifi for players and remotes. core is on cable
Squeezebox duets and touch on wifi
Controlling players mainly from PC app and Android APP (just testing with SB Remote for fault finding) . can never get lower volume then 10. slider shows below 10 but volume stays at 10.(i know cos increasing volume doesnt change any level untill i go to 11.) Mute is also “stopping” at 10. All Limits are at 0-100. same problem in both groups and “single” players.
This issue has been up for long time in diffrent forms in other treads, pls help.
Kind regs Anders
Hi. tnx for fast reply.
the slider moves but the volume stops at 10 (listning volume). be sure to have volume cos in most amps 10 is very low.
so i am just wanting to use duets for endnodes without any SB remote, just controlling volume and mute and be sure they go to zero sound.
I wanted to touch base with some good news, which is that our technical team has been able to reproduce this behavior and we’ve opened up a bug report with our developers.
While I can’t say for certain when this bug will be fixed, getting things reproduced in-house is a critical first step, and I will keep this thread up to date as the team passes along feedback and work begins to get this resolved.
