Are these threads even monitored for input to development?
I also have zones I often group and as a first iteration the most painfully thing that could be fixed(unless I miss something) is the volume leveling.. I have volume leveling set on all devices.. but when I group two or three that is reseet for the zone and the volume suddenly increases everywhere… This is not good . I have learned to quickly go into the zones setting and turn it on but it’s not a good way of handling this.. ie it should be easy to check the combined zones settings and whatever settings are the same, hsve them as default for the created zone… Sure a set zone list where even more can be setup and be a click away is even greater so I would not say no to that either.. and it’s of course what would be best… But the sudden volume increase is to me not ok..
