maybe I am just confused bit if i use HQPlayer together with Roon I am not able to permanently set HQPlayers volume out of the red and yellow range.
If I am using HQPlayer alone and move the volume „knob“ until it turns white then this is a permanent setting that will be there when i close and restart HqPlayer.
If I use it together with roon it will be set to full ( red ) volume level whenever i start Roon and HQPlayer. Is there a setting that I didn‘t get?
I am neither using Roons Volume nor HQPlayers Volume sliders and therefore would like to have it permanently set to the maximum white volume level.
Maybe somebody has an idea? If I was able to explain what I want
I used to start Roon prior to HQPlayer. I will check later if a reversed starting order will solve the issue.
If not I will follow Jussi’s advice to fix the volume by setting minimum and maximum volume to -3 dBFS. I am sorry that I did not see this solution by myself.
