All was fine one hour ago. Then, I install Amarra SQ+ to try control it using Roon by Sonic Stream. I couldn´t get it work. Then, I have uninstalled Amarra but the audio volume is too low.
Usually, I could have good volume in 70-75 on amplifier. More than 80 was too loud. Now, I need to use 90 and it´s not loud.
I´m using mac mini. Looking pictures for settings.
Are you suggesting that even though this product is downloaded onto someones home computer, Roon, at its home location can influence the functionality of remote products?
More like that there won’t be anyone around to help for a while I would imagine. As it’s working although sub optimally leave it alone, for a short time. @John_V ?
