Volumio Rivo+: wrong output in signal path
Hi,
I have a volumio Rivo+ connected via SPDIF with my DAC. Now I noticed that in the signal path the output is shown as “USB Output”. I there anything I have to change in the settings I am not aware of?
Best regards, Andreas
You won’t see the Rivo, since it is connected via S/PDIF, which has no signalling. Therefore, Roon only displays the device with the S/PDIF interface.
Without seeing the signal path or knowing what device you are using for S/PDIF, I can only assume you are using a USB to S/PDIF dongle.
If the DAC supports USB, use that interface.
Hi, I just found out that I am not the only one having this issue:
However, it seems to be solved in my case. I changed the output to USB (my DAC supports both) and back to S/PDIF, now the signal path is shown as expected.
