I have just added an album to a roon-watched directory. The album then appears in roon, but the track titles are not setting as expected. As background, I have a couple thousand albums, and have not encountered this issue before.
The album is Das Rheingold, disc 1. The problem is happening with all tracks, but if we look only the first track (Vorspiel), it will demonstrate the challenge.
The track title in the meta-data is: “Das Rheingold: Vorspiel”
The import setting “Prefer file” for track title
I have added the following custom tags
WORK: Das Rheingold
PART: Vorspiel
Nevertheless, the displayed title is being chosen (I assume) from the roon db.
After import, I attempted to coerce the title by editing the track (using roon’s UI) to the track title from the file, but this appears to have had no effect.
Please see the attached screenshots
Any clues as to what I’ve done wrong would be very much appreciated.
I have had 1 or 2 cases like this as well (cannot remember which ones though)
I got rid of the problem by using ‘edit’ and enter exact same info as in my file’s metadata.
Roon was picking up that information.
Hopefully this willl work for you as well
Dirk
I’m confident that another forum member or roon support will help me figure it out. The one other time I had a mystery, it got solved pretty quickly with some insight from the support folks.
@Akimo There is a difference between track titles and composition part names. If you “prefer file” for track titles, this will not change the presentation of identified compositions which are using composition name and part names from the Roon metadata service.
To change part names for a composition in an identified album, you need to have WORK/PART file tags — as you have done — but also “prefer file” for multi-part composition structure (there is a setting for this in the album metadata preferences).
If this does not work, please would you let us know?
