Windows operating system. Levono, yoga laptop. DESKTOP-2EMPKVT. Windows 10. 80v5. 8 GB Ram,
Att router with Meshforce booster.
iPad, I phone, bluesound vault 2i.
5338 tracks
I can’t get Roon to play through my Bluesound Vault 2i. I does work through “Other Network Devices” option Vault via AirPlay.
Why won’t roon ready bluesound device option work when enabled?
I have a Vault 2i and it works beautifully through the native Roon (RAAT) streaming path. A couple of things to try: Use the BluOS app to connect to the Vault and make sure the firmware is updated. Next, shut down the Vault, unplug from power for a minute, and restart it. Then see if it’s visible in Roon settings to be enabled.
Thank you Andy, The icon is visible in Roon settings it just doesn’t work and I have to use the Vault via airplay. I’ll try your suggestion on firmware update.
