Hi
I recently purchased a standard Nucleus which is working brilliantly. Except along the side of the top plate next to the heat sinks there is a white Light shinning through, is there anyone else having the same experience, if not is there anything I can do to rectify the problem.
It seems to be coming from the back of the power button
If you’ve figured the source of the light a bit of black tape will fix it. You can open a Nucleus without voiding guarantee if all you want to do is cover the light.
Hi Richard, we authorised a replacement last week and it should be on it’s way to you from Jon. I have the unit back here in front of me (dropped off on Friday), neither I or Roon HQ have seen this before. I don’t suppose you have a picture of it in it’s normal location / environment do you ? Trying to work out if has ben caused by heat, or if it was like that from new.
