White Noise When Using DoP with Roon Server and Emotiva RMC-1 (ref#T00V47)
· I hear distortion or noise when I'm playing music
· The issue *only affects one file *format.
Which format is giving you trouble?
· DSD
· Connected directly to my RoonServer machine
· Only one output type is affected while the other output type works as expected
· Emotiva RMC-1 via HDMI, Matrix Audio X-SPDIF3
Roon Server(not nucleus nor rock) connect to AV processor(Emotiva RMC-1) via HDMI. It shows active device, and I use DoP but only white noise I can hear. With setting to PCM, it is ok. There is no native DSD option on Roon.
If I use USB to connect Matrix Audio DAC which also support native DSD and DoP, DSD is working but if I set to DoP, same as my AV processor. Only white noise I can hear. Both PCM is working. Single Channel and Multi Channel DSD to PCM working but not DoP. Roon Nucleus also same according to my friend who has same gear as mine but using Nucleus.
It is connected directly to router.
DSD DoP via HDMI is not a standard. There may not be a component in the world that supports it. HDMI DSD is either native or converted to PCM.
AJ
Thanks for your prompt reply support for my question. You said HDMI DoP is not a standard and there is no component support it but, Emotiva RMC-1 support it. With JRiver Media Server which I’ve used for years support it too, but not Roon…
With Roon Server, my Emotiva AV Processor is connected via HDMI. Then why Roon Server with HDMI connection does not support native DSD? There is no option for it but only PCM or DoP…
Is it not yet supported? If so, is there any schedule for support it in the furure?
If native DSD via HDMI is already supported, why Roon Server does not show this option?
Hi @Stephen_Park,
Thanks for writing in to ask about this. I can tell you that Roon is functioning the way it is designed to in this case. If you wish you can submit a Feature Suggestions if it receives enough upvotes from the rest of the community it will be considered.
