Shaopei
(Shaopei Yang)
January 9, 2021, 10:10am
#1
Nucleus+(Roon version1.7)build710
NAS
I have added more than 1TB music files to my NAS not long ago.
I have imported these music files to the Roon library, but when playing, each track could not be played after 30 seconds. So did the original albums.
What’s the matter with this?
ged_hickman1
(I am not a Rabbit)
January 9, 2021, 11:30am
#4
If you could fill in the missing information especially about the network equipment and connections it would help.
Shaopei
(Shaopei Yang)
January 9, 2021, 11:35am
#5
Thank for your reply.My problem had been solved after I rebooted my NAS.Now it is normal.
Shaopei
(Shaopei Yang)
January 9, 2021, 12:05pm
#6
Some albums still have this problem.I don’t know why.Is there a problem with importing music files into the Roon Library?
Shaopei
(Shaopei Yang)
January 9, 2021, 12:19pm
#7
My router:MI router Pro(AC2600)
Media Server:Consonance R8Pro
dylan
(Dylan Caudill)
January 10, 2021, 2:48pm
#8
Hi @Shaopei ,
For the tracks that aren’t working, do they have anything in common? A specific file type or sample rate perhaps?
Shaopei
(Shaopei Yang)
January 11, 2021, 1:52pm
#10
No rule has been found yet.
nuwriy
January 12, 2021, 3:16pm
#11
Hello @Shaopei , if you load some files on a USB and import them, do you have any issues playing to system output of a remote?
Shaopei
(Shaopei Yang)
January 12, 2021, 4:03pm
#12
I shall try it.Thank you very much.
Shaopei
(Shaopei Yang)
January 13, 2021, 1:17pm
#13
It seems that playing to system output of the remote like iPad or iPhone is fine.
nuwriy
January 14, 2021, 11:07pm
#14
Hello @Shaopei , is that with the files on the USB or still on the NAS?
dylan
(Dylan Caudill)
January 18, 2021, 8:54pm
#16
Hi @Shaopei ,
If you’re able to, testing with some files on a USB drive (if you have one available) would definitely be helpful. It would help us to rule out networking issues here for sure.
Additionally, can you give some details about your audio device that is typically giving this error? Since things are working okay with remotes, understanding how the audio device is playing into this would definitely be helpful.
system
(system)
Closed
January 18, 2022, 8:54pm
#17
