all of sudden when using the Focus option for my albums I no longer see any Storage location info
I’m using windows 10 and have no issues when in Artists in Focus for storage
What may have caused this ?
Storage locations option is listed but under it now shows “no storage locations”
Can you share a screenshot?
how do I attach it ? (sorry I’m not too good with this )
Try removing the current filters…
already tried this and no difference…but if I choose “artists” instead of “my albums” all the storage info is there
I should have said Focus, not filter. You will only see 24 bit albums with 70.6kHz, 768kHZ and 96kHz. What happens if you click on the ‘+’ for each?
when I press on + for each of those they turn red and make no difference in effecting storage info…
Please remove them. Any change?
none…I’ wondering if I should just remove and redo my stored files because I just started up on Roon again and for most part playing upsampled 24 bit files so perhaps this would narrow it down since I don’t have a huge data folder to scan
I appreciate your help and have appointment so gotta go but please leave any workable suggestions for resolving this issue and note I have a number of music folders with random files that do not all show up when being stored in Roon…these are all wave files upsampled to 705/768 at 24 bit but I’m uncertain if a selection needs to be edited for storage …
any other suggestions ?
No, just what others have already posted.
I don’t think redoing your stored files is going to make a difference.
If Roon can find all your albums, then it knows about your storage.
I’m lost …can’t figure out what triggered this change …how can I present this to a Roon /support administrator ?
I just tried running Roon through my cell phone instead of Laptop and noticed on cell phone remote Roon app shows the Storage locations in Focus…??? this is very odd but I must have done something on Laptop to change this ?
I closed out my Laptop Roon and reopened and it reset to what I had established via Roon phone remote and storage now shows…
all set
