sonic transporter, ultra rendu, hq playerNetworking Gear & Setup Details
AirPort Extreme, ethernet
Hi Mark,
Can you explain in much more detail how your audio chain is setup that is currently showing the issue. What it looks like is you are running a core in a transporter sending the stream to HQPlayer via an ultraRendu.
If your issue is the inability to send music to HQPlayer than perhaps look at the ultraRendu. If it is an issue with loosing endpoints after it has gotten to HQPlayer then the issue lies within HQplayer since it is responsible for audio distribution and not Roon.
Hey @Mark_Bain,
I wanted to follow up on this thread to see if you were able to see @Rugby’s reply? If possible, more detail around your chain setup as well as the issue.
If you’re able to share the date and time the next time you see this issue occur, that would be helpful.
I’ll be on standby for your reply. ![]()
