I thought its supposed to show up between roon advanced audio transport and the WASAPI exclusive mode and cause it to go from enhanced/lossless to ‘high quality’
as you can see it doesn’t mention the volume attenuation
Doesn’t show much at all in this screenshot ![]()
screenshot fixed
Yes dsp volume is selected in device settings and lowering the db works perfectly fine
The signal path just stays at enhanced. Not that I’m complaining just don’t understand why it’s not showing in the signal chain
