MacOS 11.2.3 / Roon 1.8 (build 783)
Ropiee 3.088 running on RPi 4B
TalkTalk Router on Wifi (2.4 and 5Ghz bands available)
Cambridge Audio DacMagic 200M
Done several set-ups of Ropieee but on each occasion:
- once set up (including wifi where Ropieee happily identifies the network SSID) and moved to be attached to hifi the device doesn’t attach to wifi and doesn’t show up on the router
- on the GUI Network page (attached via ethernet as wifi not working) the wireless option is there but if you click on it the only thing that appears is the Enable Wifi toggle
- OSMC is recognised on Ropieee but the remote does nothing and no extension comes up in Roon app to use it
Endpoint shows up on Roon (but only when the RPi is tethered to an external wifi point via ethernet) and works fine that way. Volume is controllable via DSP on the Roon app.
Feedback left 360e69267e7b4dfd
Any thoughts as to where I’ve gone wrong?
