Hello
I’m considering purchasing Roon for my music. I run two systems in my house with streamers on both systems. One is a Bryston bdp 2 and one is an Aurlic. My question is… Can I use one Roon subscription to operate both systems. I only ever operate one system at a time.
Thanks for any advice
mjw
2
As long as they are being fed by the same Roon core. If fed by different Roon cores, that’s OK, but you can’t use them simultaneously. You have to unauthorize one core and authorize another core.
mjw
4
For the OP, having two cores (what serves the media files) is unnecessary in one location.
I gave him info you omitted. I think he can understand just fine. For instance, he may use one core in his house and another in his shop, out back, etc.
Yes you can Roon can feed as many hifi systems you have in your home, if they are Roon compatible to start with. Roons licence is for the server core side and is the brain of the operation, the license is not for how many devices you can serve from it this is limitless ( although hardware limitations will come into play if you using more than one at the same time)
