AceRimmer
(Smoke me a kipper, I'll be back for breakfast!)
1
I have been reading a few HQ Player threads of late and thinking it is something I should at least try.
However…
Before I dive down that rabbit hole I would at least like some advice if the gear I have at present is capable and just how I would set it up to trial it.
Onwards.
I use right now an Antipodes Edge as streamer, Roon Core and renderer going straight out via both USB and SPDIF into my Mark Levinson 585 onboard DAC…and it sounds darned good!
Obviously HQ Player cannot be added to that so…
I have the main home Acer WIN10 PC or an old WIN10 Dell laptop that is pretty much bare bones as I used it to host Roon core when I first trialed that.
I assume I could install HQ Player on either as long as all on the same network.
So idiots guide time, what would I need to do and how best to configure everything?
Kevin I have been playing with this recently on my i5 Nuc 7 (my former Roon Core)
I started off playing with Ubuntu and ended up testing HQP embedded as it is just so simple to boot up from a memory stick. I’m unsure this is the best way to do this, but it was certainly the easiest to get going with.
I will follow this thread myself to learn more.
I had that sending audio to my Zen Stream and out through both SPDIF and USB
With embedded and the Zen Stream I was listening via Roon in about 20 minutes and most of that time was scratching my head about what I needed to do. Then I had music (and a lot of fan noise )
Look forward to see where this thread goes
AceRimmer
3
It’s going to be on one Win10 PC or another for now as really not too interested in buying anything else right now just to test it out.
And if that’s not feasible then it’s likely a still born project for now.
So you could install windows app or boot off a memory stick with embedded version.
Took a couple of mins to write the memory stick and boot up. Then no issues or other windows software to get in the way
Fan noise from start of playing music, the Nuc is in its original case and I think I pushed it a bit hard with some of the options I chose. I can tell you the chasis got a bit
I have been following one of your other thread’s since then and dialed the settings back a bit. But with travel and holiday I have not really had time to get back to it as I was hoping.
If you want to use Windows with HQP Desktop then obviously that machine won’t get a new IP address just by installing HQP Desktop
But it might if you run HQP OS on USB stick. It boots a custom Linux OS. You can’t run Windows simultaneously. It wont do anything to your Windows install as Michael mentioned earlier
AceRimmer
14
I m obviously missing something, I set hqplayer as audio zone in Roon and when i hit play it shows as playing and the signal path looks fine but I get no sound out of my system.
Now also when I look in hq player settings it does not show my dac at all so I cannot select it, I assume that is the problem.
We went in circles before asking for overall system layout which would have solved the issue earlier
So can you detail your system config
What machine is connected to what, is it USB or ethernet , what is in same room or different room
AceRimmer
16
Sure!
The win10 pc I installed hqplayer on is upstairs connected to router by Ethernet.
Not connected to anything else at all.
In my music room downstairs is a unmanaged switch directly connected by cat6 to the router upstairs.
This connects by Ethernet to the Antipodes Edge which is streamer, Roon core and renderer.
This is connected to my Mark Levinson 585 internal dac by both usb and spdif, simply because I am still continually comparing the two.
The 585 dac is limited to 24/192, which is exactly how I have Roon up sampling to and works perfectly on both inputs from the Antipodes.
This is screenshot of the hqplayer signal path just in case.
Since your HQPlayer is in a different room obviously you can’t connect a USB cable direct to your DAC.
That’s why that other thread went in circles for a few days - we didn’t know DAC and server were different rooms and endpoint only supported Roon, not HQPlayer
AceRimmer
19
Well that’s saved me a lot of aggravation….mucho gracias!
Part of the reason for getting the Antipodes was to eliminate lots of boxes and cables which it has done spectacularly well.
If there is no way to use hqplayer with what I have then it’s a non starter and this was very worthwhile and all the help is very much appreciated indeed.
But I really don’t want to add anything else if can’t get it to work with the Antipodes.
I will email antipodes later to see what they have to say about hqplayer native support.
AceRimmer
20
Amazing what you can learn by reading the manual…….
