Hello Harry
First of all, thank you very much for your stunning software. I have three RoPieeeXL endpoints running faultlessly in my house. Your work is much appreciated here.
I have, though, a problem with a new endpoint that I want to set up. This one is running on a Raspberry Pi 2 Model B Rev 1.1. It has been working great on a wired ethernet connection. However, I want to move the position of it, and will now have to go wireless. I have two wifi dongles available, which are both recognised by RooPieeeXL (on release 396),
If I ssh into it, and run the lsusb command, with either one of the dongles inserted, then it correctly returns details about it:
- Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
or - Broadcom Corp. BCM43143 802.11bgn (1x1) Wireless Adapter
In the network tab of the software, I get the “wireless” box and it sees my LAN, and I can enter my LAN password. However, that is as far as it gets. If I reboot the raspi without an ethernet connection, I just get a rapidly flashing green light. and no network connectivity.
Am I using unsupported wifi dongles?
