Hello,
I have two RPi 4B 4G running the latest RoPieee. Both connect to the internal network via the internal Wi-Fi adapter. One 4B controls a USB DAC, the other has a Hifiberry Digi2 Pro HAT.
With both, I have problems with Wi-Fi disconnections, sometimes very often, sometimes reasonably tolerable, but never stable.
I tried to run the 4B with the HAT using DietPi. I encountered the same problems with that too.
I operated the 4B with the USB DAC and a Realtek USB WLAN adapter with RoPieee. The adapter was recognized immediately and the system ran right away. The WLAN disconnections were significantly fewer, but unfortunately still present.
Both RPis are located in close proximity to a Wi-Fi repeater and the transmission rate is excellent.
Does anyone have any ideas about what else can be done to achieve stable audio transmission without interruptions?
I know that I can achieve this with an Ethernet connection, but unfortunately I can’t use that without drilling holes in the wall, and I want to avoid that!
Thank you very much
Ralph
