Hi!
Since Roon on my iPAD Air2 is the only APP reconnecting time by time would it be possible to set the reconnetion timer not that sharp??? i guess it is in the ms range (my WLAN latency is 200ms max.)
I use Lightning DS and BubbleUpnp (android) as Remotes and they never have reconnect issues.
The music stream continues though so seems buffer mechanism works between Core and Auralic Aries.
Best regards,
Armin
NOA
November 25, 2016, 5:14pm
2
+1
Discussed already a few times in this forum but Roon seems not to hear it.
WiWavelength
(Andrew J Shepherd)
November 25, 2016, 6:30pm
3
Or, because it has been addressed too many times already, people seem not to want to research before posting and/or not to want to hear that the issue lies with Apple. That is just the way it is.
AJ
fact: no other app on my ipad shows that behavior
now Roon can play PingPong with Apple or try to get them into it, i personally think:
do what has to be done for best service for your valued customers!
best regards,
Armin
WiWavelength
(Andrew J Shepherd)
November 26, 2016, 12:14am
5
Armin_Moesslacher:
Lots of reading for you…
https://community.roonlabs.com/t/roon-1-2-can-the-ipad-or-iphone-now-stream-music-or-not/9553/
Using build 88 on an iPad Air 2 and finding that when I switch away from Roon to say check email, when I switch back, Roon says disconnected from server and needs to reconnect. It’s not a big deal, but a little distracting with the screen flashing back and forth. Is it possible to keep the connection alive or wait longer before the disconnected screen shows up? Thanks.
Roon app does not show up in ‘background Refresh’ settings (Settings>General>Background App Refresh). Running latest iOS (9.3.5).
Will the Roon app be updated so that background refresh can be set?
What determines the response time on my iDevices ? The server HW ?, as long as you know for sure your home LAN is fast. Local files is not on same device as Roon Core if that matters. All network hard wired.
Every time I close the iPad, or switch to an other task, the app “loose” connection with the core. I suppose this is how it shall or is intend to work or ?
Even the iPeng app was faster if I rememberer correctly.
Can I set some sort of keep alive state or time ?
This is not a problem, th…
AJ
Yesterday Roon was in the foreground all the time still reconnect issues.
Also battery drain is high (probably IOS no other Apps running in background).
If queue view is on no problem, album view returns back to 1st album ;-(
best regards
Armin
Can Roon implement the Mac OS app to stay idle in the background (there are some Apps like Skype where i can choose the setting on my iPad
