In composition section which I am using a lot, you find full work next to small extracts coming from recitals (eg. Full Traviata next to some arias sung on recital albums). Would there be a way to filter only full versions on those works?
I have been asking for this for as long as I have had Roon. Nothing has been done. Even a simple playing length filter would be a lot better than nothing to separate out the extracts from the whole work. If you have Qobuz you can end up with hundreds and hundreds of search results for a composition most of which aren’t of the whole composition. Hopeless.
@Danny you may want to look into this one.
We should be so lucky.
