Hello,
I just integrated a Yamaha YSP-2700 Soundbar as playback device via Airplay. Every few seconds the Subwoofer stops playing for one or two seconds and then comes back again. The rest via the soundbar itself sounds just as usual.
When I use Airplay without roon it works perfectly.
Does anybody have an idea how to fix this?
Thank you and best regards
Claus
You can try telling Roon to convert everything to 48/24 as that is the format it would expect for TV use.
Hi Henry
Thank you very much. I can’t find such settings in the settings for Soundbar in Roon. Do you know where I can do that?
Claus
Roon automatically is sample rate converting, if necessary, to 44.1 kHz for AirPlay compatibility. That should not be the problem, nor need be adjusted in settings.
Honestly, this does not at all sound like a Roon issue. Rather, it is a Yamaha issue. Try Yamaha tech support.
AJ
Hi AJ and thank you very much.
I will try the Yamaha tech support.
Cheers
Claus
