I am logged into Tidal and successfully play from the embedded Tidal app.
However, when trying to locate Tidal when browsing filter to Storage locations, Tidal does not show, so I can only browse my LAN library (i.e., HD location).
Tidal has been showing before under Storage location.
So, in order to check for different resolutions and sample frequencies on Tidal, one have to add one Tidal album to Roon library first, for each of the formats you intend to search for……
(Or can you only search within the added Tidal tracks in Roon by using the Inspector and not within Tidal global online library through the embedded Tidal app??
AFAIK, you cannot use Roon to find all Tidal albums with a specific sample frequency or bit depth.
The “My Albums” view will only show you albums that you have added to your library.
For any specific album, you can always use the Version tab on the album to check which versions are available, This will show the bit depth and sample frequency, but this is on an album by album basis.
