Best cable to connect laptop to streamer
Ahhhh that’s like asking who shot JFK!
They are all the same as long as well made. Amazon basics, belkin etc.
Any cable, whether Ethernat or USB or whatever, that is up to spec is more than adequate.
I have a mixture of the cheapest AudioQuest cable and BlueJeans cable. BlueJeans cable will custom make your cables to length, etc.
I have bought cables from Amazon suppliers that have not been up to spec. I’ve had trouble with both HDMI, the most egregious, and with Ethernet cable over 25 ft.
I resemble that remark!! @ged_hickman1 :slightly_smiling_face:
Thanks for your replies. I’ve gone with UGREEN. I presume they’ll be more than adequate?
Pete
Haha. Hope I haven’t opened a can of worms!
Me again!
I’ve connected my laptop to my CXN streamer via ethernet, everything seems OK. How do I connect roon to my CXN?
Pete
Don’t worry, I’ve worked it out!!
Hi Mike,
I’ve connected via ethernet. All seems fine, but I don’t get any artwork on the CXN. Did you have any problems?
Pete
Another question I’m afraid. What is an RPI?
Raspberry Pi.
A little hobbyists computer that has been used in everything you can think of that computer geeks can get up to. Including HiFi.
You can buy add on boards, for example, that plug onto the Pi and make it into a very good roon network streamer and DAC. All for £100 or less.
Quite a few high priced commercial products have a Pi inside surrounded by refined power supplies and casework.
Thanks for the reply!
Just in case you ever have a dull evening and need some reading.
https://community.roonlabs.com/c/audio-products/raspberry-pi
Thanks Ged.
It depends on how it’s connecting
Roon will see CXN as an Airplay speaker, it will downrate everything to 44/16 but you will get artwork
If you have amn intermediary device then to the CXN D1 input you’ll get native hi res with no conversion but no artwork
It’s the proverbial rock and hard place
How have you connected your router and ethernet
My router is a Virgin Media superhub… Ethernet from laptop to router, Ethernet from router to CXN
There must be some funny with router
Mine does
PC - Router - extension cable - switch -CXN
Which is much the same,
Roon to CXN via AirPlay gives artwork, I’ll check again
That will downscale everything to 44/16 yes
I’ve got both a USB connection direct to the CXN and Ethernet via my router. Both work fine but no artwork from either on the CXN.
Talking about USB audio. I’ve installed the CA USB 2.0 driver on my laptop as per their instructions, but when I switch to USB 2.0 on the CXN, silence. Anybody had the same issue? USB 1.0 works fine.
Having both connected may be confusing things, try just the Ethernet.
Seems to be working now.
I mean, album art showing on the CXN via Ethernet.
