I also use MP3Tag Editor for years. All my Files are matched against Discogs.
Most of my Boxset are already fine, some needed a bit adjustments in the Tags.
Not much to worry. I’m now trying to get the largest Box-Set to fill with the proper posters (some are missing). Contains 31 Discs. Most of the Albumart is shown, but some are unidentified.
A bit of work for some but for the majority it went without issues or work.
I first check with Roon
If the single disc is not listed, then I go check my Tags in the files.
Then I search Discogs for the Release
Then I copy the Release ID from the address bar
In MP3Tag, I use Search Discogs Release ID:
And then add the Tags
If its still not proper in Roon, then I download the proper poster from discogs, and assign them properly to each disc in MP3Tag.
In my example, even with all the Tags set properly, Roon was still not able to Identify the discs.
But with Renaming the folders by adding the title of each disc in the foldername, Roon showed the correct Title and the proper albumart.
Only the date is still missing, due to unidentified. But the year could also been showed there, every disc is edited manually.
I’m fine with the result and keep it this way. I only have 25 Box-Set with more than 10 discs - so the amount of work is not that big.
Proper tagging is the key (was always)
