FS: Mytek Brooklyn Power Amp +**Reduced**
Excellent Class D power amp from Mytek. XLR + RCA input for connecting to pre amp. In fantastic condition, comes with original box. RRP new is £2300.
Price is £1299 ono inc p&p
Description: Class-D amplifier with bridged-mono mode. Power: 250Wpc into 8 ohms (24dBW), 300Wpc into 4 ohms (21.7dBW), 400Wpc into 2 ohms (20dBW). In bridged mono: 500Wpc into 8 ohms (27dBW), 600Wpc into 4 ohms (24.8dBW). Signal/noise: >121dB. Frequency response: 10Hz–30kHz, –3dB. Total harmonic distortion: <0.001%. Damping factor: >400. DC power on trigger: 12V. Power supply: 100–240V AC 50/60Hz, automatic switching.
Dimensions: 8.5" (216mm) W × 1.74" (44mm) H × 8.8" (225mm) D. Weight: 6lb (2.73kg).
Mytek Brooklyn AMP Power Amplifier is a major upgrade of the amazing Brooklyn AMP sound. It retains the same type of sound with dynamic and precise transients, extended frequency response, reduced low level distortion and cleaner more natural, spacious and analogue-like character.
Low Level Detail
Brooklyn AMP features new faster transistors, cutting the so called “switching dead time” to low nanoseconds and faster and higher 650kHz carrier clock. They both contribute to greatly improved low level detail and lower distortion. In addition the output filter frequency has been increased two fold for lighter highs and to better accommodate difficult loads.
Reference Amplifier
Brooklyn AMP is a reference power amplifier with signature Mytek sound – musical, detailed and transparent. Its dual mono design breaks the sound quality spell associated with Class D and proves a well executed Class D circuits can challenge the best Class A and sound amazing.
The amplifier is packaged in a miniature 1/2 rack enclosure and it’s small enough to fit in a briefcase, yet powerful enough to drive the largest speaker systems. It’s designed to be used as regular stand alone power amplifier or to complement Brooklyn DAC for a complete modern digital streaming and vinyl playback system.
Mytek Expertise
Mytek engineers with the lead designer, Michal Jurewicz, have demonstrated that a carefully executed Class D can sounds like triode, with beautiful midrange and depth while maintaining deep bass and fast transient and detail. Mytek extensive expertise with DSD, technology similar to digital amplifiers was used in this project.
This architecture allows for packing a lot of power (300W/ch) into small 1/2 rack chassis, small and light enough to be carried around in a briefcase. Existing Brooklyn AMP owners can upgrade their units to Brooklyn AMP specs.
Reduced to £1199 or best offer
Reduced to £1149 or best offer
