I use it to help me figure what version of a CD I have. All my 12,000 discs are ripped and have been put away in storage. I can take the DR number I generate using foobar2000 and look it up in the DR database and it gives me an idea of what release I have.
Once I know there may be a better sounding version according the people at the hoffman forums I can then start trying to track it down for albums I really care about.
For me is, and donāt get me wrong I think for the value levelling point of you this is a great advantage, that the values are per practically meaningless unless you are comparing two versions of the same album as per this post
If it is an easy thing to use what we more conventionally understand as DR VALUES well and good if itās not, no harm done and still enjoy Roon as I always have done.
That would require all of us to making sure we have the correct CD pressing and date data otherwise all we know is there is another version of an album with better or worst DR values.
Is it the original 86 disc, the 91 remaster or the 2015 remaster, the SHM version, the MFSL version etc etc
Indeed, excellent ambition but I agree it would be impossible to ensure people were assigning their DR rating to the correct pressing/release. Great to hear @danny and co are interested in this in some form though!
A design of a product that makes accurate mapping irrelevant would also be helpful⦠for example, if N users had M discs each with a varying range⦠only the best of M would need to be identified accurately, and that might be doable manually upon request.
Building crowd-sourced products requires thinking about data in non-accurate-non-concrete terms.
Does that also mean that all our metrics in 1.3 may be used later as a crowd-sourced measurement?
As I expect currently nothing is send back yet to a big Roon database on your side, right?
Please add a switch in one of the next releases so we can start supplying you that data
Btw, I saw you mentioned something like this before in another thread:
I donāt want to get into too much detail about how weāre looking to improve Radio after 1.3, since the plans are fluid and could still change. I can tell you we think an important source will be what we capture about how people are already using Radio. Weāre now at a point where we have a critical mass of users generating this data, and 1.3 will contain client-side functionality to help us gather that data before itās analyzed in the cloud.
I agree with you that a DR metric is most useful before buying an album. That said, I found it useful to analyze my existing albums. Sometimes Iāll listen to a track and it sounds offā¦something wrong. The DR metric helps me understand itās a compression issue with the track and not something wrong with my setup.
Great idea. DR is so useful for comparing different versions of the same album. I have 4 versions of Off The Wall but 2 have a shockingly compromised DR that I donāt bother with them. I even use the DR database to decide which version of an album I want to buy.
Itās not everything though of course. Most, if not all, versions of Blue by Joni Mitchell have a low DR (even the vinyl) but that will never stop it being a classic until the end of time lol. So I wouldnāt use it to determine whether to get a particular album - moreso which version of that album.
The DR database gives Thriller the following values. Jap CD 1st pressing = 15 and 2008 CD remaster = 8
Roon is giving both a score of 5.
Itās quite possible the DR score made me give biased preference to the 1st pressing and made me hate the 2008 remaster. Iām very open to that idea.
Or maybe Roonās R128 calc is off. Or both are wrong and we should actually listen and not be swayed by values lol.
Or we should have both values shown in Roon. Iām confused but this is fun and interesting lol
Choose a Track and look at the Waveformā¦and repeat the same for the 2008 remasterā¦take screenshots and post them here if you like
IMHO, itās best to look at BOTH the Waveform and the R128 value to get an informed opinionā¦the Waveform will help give a guide to perceived Loudness, while the R128 value will guide towards the Dynamic Range within that relative Loudness
And lastly, the Crest DR should be called a āGuideā rather than what you describe as a āScoreā, which sounds more like an āinarguable resultā, which IMHO it is not in all cases
