Just had a thought - you could try some powerline kit - I used a pair of these for a while to get a connection out to my studio at the end of my garden (they are sat in drawer now as I stumped up to run ethernet). I think for the relevant distances you are looking to cover you might find these quite effective.
Powerline Adaptors
Word of warning though (advice really) you need to use the power passthrough with any audio device you connect to these as the unit itself helps to filter the noise they introduce onto your power supply.
Thank you, will try this out
