I responded to your email. It seems you have a network connectivity issue that is most likely interfering with the embedded roku emulators.
Details and actions in my email.
By the way, unlike probably every 3rd party software outside of logitech and their partners, this does not use XMPP and instead uses their new control protocol. Neither does XMPP have a part to play in the connectivity with the roku emulators. End result - no need to enable XMPP.
Is there a more detailed guide on how to set up an âactivityâ correctly. I am completely lost here. My hub is showing up in Roon and I have the dummy TLC device adde to my hub but I am a complete loss how to set up the activity and the github page isnât really clear at all.
do you mean setting up the activity in the Harmony app or configuring the extension in Roon? I found the latter to be more confusing. Setting up the the activity in the Harmony app is reasonably straightforward. Below a few screenshots of my set-up with an amplifier, DAC and the Roon Control (TLC device). It is also important to configure the buttons of the Roon Control device correctly (as described in the GitHub page). Hope this helps.
Thank you for you reply. I figured it out in the end. The part I was missing is that you need some dummy audio device to setup a âPlay Musicâ activity. Now it works perfectly many thanks to the creator of this.
Hi, can someone help me please. I was running previously deep harmony extension for my NUC/ROCK. The extension is always running on my laptop Win10. Last week I had to recover Windows10 on my laptop and now canât get the extension working again. Roon sees the extension but the status is âawaiting harmonyâ. Please help because Iâm stuck and donât know what to do next.
You donât need a RPI 4 in order to create an arm64 image. First of it can also be done on a RPI3 , but there is also the possibility to cross build the image by using a Multiarch image as your base image. Most of my extensions are nowadays based on Multiarch.
I created the Extension Generator to make Multiarch image creation easier. Maybe a look through the different scripts can tell if this is an interesting solution for you.
With multiarch you can cross compile for the target platform.
I created a Dockerfile that can create images for multiple architectures containing a compiled version of an extension (Iâm using the pkg compiler). It is a two stage build, in the first stage the binary for the extension is created and in the second stage a run time image containing the binary is created. The resulting image doesnât contain the sources.
Before building you have to activate the multiarch environment:
docker run --rm --privileged multiarch/qemu-user-static:register --reset
The target architecture has to be supplied at docker build time via --build-arg options. As architectures can have different names for different tools there are 2 of these build args. These are the values for arm64:
I use a Roon ROCK on a NUC and I have a Synology NAS on my network. I succesfully install Docker and the Deep Harmony. Roon see the extension, but Iâm stuck with the Harmony Software on my phone which is unable to discover anything on the networkâŚ
Some help is welcome.
Hi Sylvain,
Iâve had the same problem. Today I solved it finally. Try with previous version of Deep Harmony Roon Extension. I downloaded version v2.6.5 and everything works fine for me.
I seem to have lost the ability to change volume and mute/unmute from Roon. I tried erasing all settings and setting up again multiple times but that didnât help.
Thanks, but unfortunatly, there is no version for my DS916+. Iâm only able to install version which are in the docker register in my Synology. I have tried with the 2.6.0, with no successâŚ
Looks like my issue was the way I added my new pre-amp to Harmony. I selected custom instead of receiver/amp so Harmony did not see it as a volume control device when adding it to activities. Re-added it as a receiver/amp device and reset all of Deep Harmonyâs settings and now it works as expected.
Just found out about Deep Harmony and really want to try it to control Roon as I donât have a remote for my streamer. But I canât seem to get even to the point of installation. Iâve tried on two different Macs, an Intel Mini, which is also where my Roon Core is installed, and an M1 Macbook Air, and same result on both.
I downloaded the correct version (roon-extension-deep-harmony-v2.6.7.387-macos-x64.zip) for my operating system, Mac OS Big Sur 11.6 to my âDownloadsâ folder.
I unzipped the archive and it expands as it should. Resulting in the following:
As per the instructions, I open a terminal in the right directory and type: ./run.sh
But this results in: zsh: permission denied: ./run.sh
So I try: sudo ./run.sh
and enter my password and get: sudo: ./run.sh: command not found
Probably, as usual, Iâm missing something simple here, but any help would be appreciated.
