Something else
None of the above
I want to report a metadata issue
192khz 24bit 2ch is automatically downgraded to 96khz by also initiating bit depth conversion?On the other hand 352khz do function as usual
Hi @Guido_Buehler, Thank you for writing in to let us know about this issue. It looks like the picture you attached did not upload properly. Please try to reupload it and also include any DSP settings you are using and the signal path you see.
