I have an album that has correct meta data and are in their own file. One album name is The 20/20 Experience and the other the same but with part 2 in the name. Roon thinks these albums are the same and when I research for the album I can see both parts but can only label both parts one or the other and not separately as its supposed to be.
Will this be fixed outside of me messing around in Roon settings? I know my metadata is correct as I have checked it all with mp3 tagger.
You can use Roon’s Fix Track Grouping feature to separate the albums.
Select the album, click the 3 dots menu and click Edit. From there click Fix Track Grouping.
In the right hand column, select all tracks from one of the albums. Then click Remove Tracks, which will remove the selected tracks from the album you are editing, don’t worry it won’t remove the tracks from your library.
You should then see, at the bottom right of the window, Create 1 album with ## Tracks. This album should match one of the two merged albums that you’re trying to separate. Click Create Album.
You should now have 2 separate albums and hopefully Roon has automatically identified them correctly.
