2nd Rating for Sound Quality
The current rating is used to rate the quality of the album. With so many different releases these days of the same album, it would be helpful to add a Sound Quality rating. I’m not expecting this to be field ingested from source, but one made available to the end user. As an example, there are a number of releases of Miles Davis Kind of Blue, some are good and some not so. It would be nice if we had the ability to rate our versions of albums as we hear them.
As a workaround you can create a set of tags to achieve the same ends. You can then easily find all your best quality versions in a few clicks. If Roon ever implemented your suggestion, the tag information would be easy to convert.
@Anthony_B thanks for the suggestion. I’ll give it a whirl. I listen to lots of live recordings, many very old. Some of the concerts are gems while maybe the recordings are not so good. I’ve been torn with the User rating of do I mark it poor when the playing was outstanding? Possibly tags is a way to go.
