A simple way to copy to clipboard current artist playing?
Hi all. anyone know of a simple way to copy the current playing artist to the system clipboard (im on mac)
maybe something in AS/JS/other i can then bind to a key on the mac
thx!
z
Sorry can’t be done. It’s a common feature request but the way Roon displays graphics doesn’t allow copy/paste. The trade off allows Roon graphics to scroll quickly. Try scrolling with competing products like JRiver and you’ll see the difference.
i see
thx @David_Gibson for your answer
best regards
Z
You just have to use Roons inbuilt share feature on the album or artist of choice for this and use the copy link option.
thx @Simon_Arnold3 !
can you share an example? is there a key bind option or programatic way to do so?
best
Z
You can’t clip anything it’s not text it’s rendered through a game engine so it’s just graphics.
The share is shown here
