Absolute Sound 1.8 Review - May 13, 2021
How hard is it to build you own NUC to run Roon? Here’s a quote from someone after a build: “It took literally 49 seconds to install and after that simply run Roon, select the core (which popped up immediately), and copy my music files to the internal 1TB SSD I installed.”
What the heck does the quote have to do with the difficulty of building a NUC?
