Hi All,
did anybody already have been successful in setting up an active crossover with the convolution engine in Roon?
I just tried, but only got strange results.
Is this finally possible at all?
Ok, assuming, that I have an output device with e.g. 8 channels like a typical professional multichannel DAC (e.g. Lynx Aurora, Focusrite Rednet …) how do I have to configure this in Roon?
I assume, that on Windows, you have to use ASIO for multichannel, as WASAPI always creates only pairs of stereo which are shown in Roon as different devices.
If I chose an ASIO device, how do I have to configure the device in the device settings for a multiway crossover configuration?
Which device configuration do I have to use?
Which channel layout?
Which multichannel mixing strategy?
I tried it with a 5.1 setting, which would fit for a 6-way crossover, because any other configuration creates a channel mapping in the output path, which does not seem to fit.
My config file looks as follows and was accepted by Roon:
96000 2 6 0
0 0
0 0 0 0 0 0
Cor1L96.wav
0
0.0
0.0
Cor1R96.wav
0
1.0
1.0
Cor2L96.wav
0
0.0
2.0
Cor2R96.wav
0
1.0
3.0
Cor3L96.wav
0
0.0
4.0
Cor3R96.wav
0
1.0
5.0
For convolution, I used filters created by Acourate (I tried dbl an wav mono files), but the output is only a distorted noise.
So what am I doing wrong? Are there any other aspects I have to watch out?
Thanks for your help
Matthias
