I own two iPads each configured as remotes. I recently set up the older one as a dedicated remote that is kept and charged in my music room. The other is my working iPad with my apps, including the Roon remote app. I am experiencing intermittent server connection problems with the older iPad.
Is there a known problem with connecting two iPads as Roon controllers in a single system/server? Or is it likely that the older iPad - still supported by Apple - is just too old?
I use two always on, always connected iPad controllers with no issues. One is in my listening room and one in our sunroom. The older is an iPad Mini 6 and the newer is an iPad 10. Both are connected to a Nucleus.
Thanks. I have reset the older one, downloaded a clean app, and connected the iPad to my server. I will test it out once my Broncos are finished with NE!
AceRimmer
("I’m not just a hero; I’m a legend!")
6
Also check that the older iPad is on the same latest firmware version as the newer one.
I can’t see why it would not be but one never knows.
