Hi @spockfish - I went to the web interface of my Allo DigiOne which is running RoPieeeXL and it displayed Update downloaded and available for your device! I clicked on INSTALL UPDATE and it went off on its way, losing contact with the browser. A little while later, I opened the page again and it was still showing the INSTALL UPDATE button. I clicked it once more and now it won’t come up at all.
I have unplugged the device and powered back on and still not seen from the web interface or from Roon. The green LED is slowly blinking (once per sec).
I have another device that I’m using just for the display also running, but I have not tried the upgrade there. It is currently running 2022.06.1 (373)
Hi Harry- It is still unreachable, does not show in the devices tab…
I decided to just do a fresh install, so I downloaded the latest image and flashed the SD, now it is not booting
Going to bed, I will take it up again tomorrow. If you have any recommendations, I’d appreciate it. I will try this new SD in my other unit that is running. I’ll swap the SDs between them and see if I have any luck.
The display unit was able to upgrade itself automatically, so I still don’t know what could have caused the initial problem, but it looks like all is good now:
