Hi. Via roon I want the allo digione sig to output no more than 96khz to my dac. I use Lexicon mc12 and that’s it max res. Can I set max to 96khz somewhere in roon or even on digione sig? Thank you.Julian
Under device settings you can set a max resolution.
I haven’t seen that option, only bit depth?
Then under dsp, set the upsampling rate to custom and set everything to 96
