Pixel 7 Pro user here. Disabling audio routing does not work in my case. Different DACs just crash immediately when having the USB driver enabled.
I recommend hammering the Roon team in the recent survey to get this fixed ASAP.
I think they should fix bugs first instead of introducing new features. It does not matter that it has the “beta” tag. Imagine putting beta tags on everything that does not work instead of fixing it.
Disabling audio routing fixed the crash problem for me too.
Pixel 8 pro with android 14 and a Cayin RU7 dongle Dac.
I read that Google wants to enable bit-perfect output under Android 14 on Pixel smartphones. This should come with the first Android 14 update, but it doesn’t work directly yet.
Fixed an ARC crash issue on certain Samsung devices when using an external DAC.
Although I have a Pixel 7 Pro, of course I tested immediately. After first getting a new error message “Error communicating with USB DAC”, right now I am listening in bit perfect with my Focal Bathys in DAC mode. I hope it stays that way
EDIT: @cinematic: I don’t know if it might have been the latest Android 14 update, that fixed it, though. I did not test before the Roon update.
Hopefully I can try that this evening or tomorrow as my Pixel 7 Pro has not worked in a long time.
I got the latest update last week, so it will be a good test
Hmmm they have form for this as iOS lock screen control is still beta and it’s been out for 2 years and it’s been broken just as long by sending your audio to 100% when enabled.
There was mention sometime last year that it might come eventually, but given the challenge of making it reliable I can understand why it has not yet been implemented.
Android 14 has functionality to make this easier to support for developers, but it has been a challenge to get working as Google seemed to break something in the final release (or removed it) that looks like they have fixed in the latest QBR.
Hopefully it makes it easier going forward to get it working on Roon Remote🤞
Thanks for the reminder. I don’t use ARC very much so I have not tried it in a few months.
I now find that with the latest releases build, the USB (beta) driver seems to be working fine on my Pixel 6 using a Fiio BTR7 without having to resort to disabling USB audio routing using the developer settings.
Just finished listening to the third 96/24 track in a row with no issues. If it gets to nine I think I shall declare the issue fixed for me.
They may well have overcome the issues for ARC, but it has taken a while. I would imagine that Roon developers would be loath to copy the solution to the Android Roon remote app whilst issues were still being reported on ARC on Android. Also, whilst It now appears to be working for Pixel 6 (mine) and Pixel 7 running the latest Android 14, what about all the other devices running potentially older versions of Android.
I suspect that they will not start working on bit perfect for Andoid Remote until they are completely happy that the solution is stable (beta qualifier removed from USB driver in ARC?).
Ha ha they only just got it working for ARC and I think it still doesn’t work for all, or maybe even most.
Ideally when it comes out of Beta they will put it in Roon Remote.
There are many DAP users who also want this for their very good built-in DACS as well.
Well. That is a result! Finished the whole album (1 hour and 20 minutes) and most of a following album (although I wasn’t listening for most of the latter because I had to join the family for lunch) and ARC was still playing happily in bit perfect when I got back.
This is a marked improvement for me. I could only get reliable bit perfect playback on ARC before if I turned USB audio routing off (which I found too intrusive so I never did). Before it would typically lose the connection to the USB DAC after about 15-30 seconds (although once or twice it went to about 15-20 minutes).
Google Pixel 6 with Android 14 (latest update installed yesterday) connected to a Fiio BTR7 playing balanced to my HiFiMan Ananda Nano headphones
