Nucleus Plus - 4TB running Roon 2.0
Verizon router with 1GB speed. eero mesh network - Nucleus wired to an eero satellite
Latest Mac Mini, iPhone, iPad
6,000
Nucleus Plus and the Mac mini Room app are both 2.0 and everything works fine with Room apps, both Mac and iPhone. Arc app on the iPhone will connect when I’m on home WiFi but will not connect outside of the house either on cellular or another WiFi connection.
One interesting thing - while connected to Arc on the iPhone if I quit the Arc app, disconnect iPhone from WiFi, Arc will then connect via cellular right after I shut the iPhone WiFi down. This is not a case of Arc continuing to play cached music; I searched for and played new songs not in my library and Arc is working fine over cellular. If I then quit Arc and try a few minutes later (still on cellular) it will not connect.
I’m not very tech savvy and am hoping someone can offer some trouble shooting tips an “oldish” guy can follow. Thanks so much.
Ken
