NUC
ORBI, no VPN
Multiple Roon Ready endpoints, Bluesound, Apple TV etc…
Just under 7,000
Can’t get Roon ARC to work. I installed it a while back and it worked but when I got a new iPhone it doesn’t connect. I’ve tried turning off UnPNP and then putting it back on. Router and Core have been rebooted several times. Error codes are below from 3 different tries.
“external_ip”: {“actual_external_ip”:“47.aaa.bbb.ccc”,“actual_external_ipv6”:“null”,“router_external_ip”:“null”},
“upnp_autoconfig”: {“server_ip”:“10.0.0.1”,“found_upnp”:true,“error”:“<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/\” s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/\“><s:Body><s:Fault>s:ClientUPnPError<UPnPError xmlns="urn:schemas-upnp-org:control-1-0">501ActionFailed</s:Fault></s:Body></s:Envelope>”}
“upnp_autoconfig”: {“status”:“NotFound”}
“upnp_autoconfig”: {“server_ip”:“10.0.0.1”,“found_upnp”:true,“error”:“<s:Envelope xmlns:s=[http://schemas.xmlsoap.org/soap/envelope/\](http://schemas.xmlsoap.org/soap/envelope/) s:encodingStyle=[http://schemas.xmlsoap.org/soap/encoding/\](http://schemas.xmlsoap.org/soap/encoding/)><s:Body><s:Fault>s:ClientUPnPError<UPnPError xmlns="urn:schemas-upnp-org:control-1-0">501ActionFailed</s:Fault></s:Body></s:Envelope>”}
Thanks for any help
