I upgraded to 196 and my Audio Analysis started back to zero and has restarted. I was half way done with analyzing my music. Will this happen each time there is an upgrade?
No – it’s really only when big changes have taken place (in the case of 1.3 the files needed to be reanalysed for R128 volume levelling).
Did you have any previous 1.3 (B19x) build installed?
My mistake, yes I was up on 1.3 and did the upgrade. What I just noticed, after reading your reply is the new total of tracks to be analysed changed from the over 40000 to 21K. So the new count stared a 1 to 21k, the number left prior to the 196 upgrade. Thanks helping me understand
