audio quality display in Naim Uniti Atom
Does anyone use the Naim Uniti Atom with Roon?
When I listen to tracks from Tidal on my Naim Uniti Atom (Headphone Edition), the display shows the audio quality in kHz of the track I am listening to.
However, if I listen to a track from my Roon server (on my MacStudio), this information is not shown. Is this normal, or is there any way around the problem?
Depends on the Atom, I don’t think it does show this info with Roon. But you can see it in the Roon app (and in more detail), maybe this does what you want?
No its normal, it simply shows Roon Ready and no further signal details , just the track name and artist etc
Mine is the HE too , but it’s thing with the app. Airplay equally shows no detail.
Thank you! Yes, I can get the details in the Roon app. Just curious if the Atom can display them, but I don’t think so :wink:
Ok, got it! Thanks!
Are all of you happy with the headphone edition? I’m thinking of buying one for my home office desk.
ABSOLUTELY
It’s my only source for the last 2 years I have no speakers, amps , streamers etc
One LAN cable , one power cable , one headphone - simplicity itself couldn’t recommend Higher
I run 3 pairs , Sennheiser HD800, Focal Clear Mg and HiFiMan Arya Stealth . All 3 sound sublime .
I too am satisfied. I use it with my ZMF Verité Closed, which sounds great.
  • m.
