When I disconnect CarPlay ARC starts playing again.
No other audio apps I have do this, and disconnecting from audio source should pause ARC.
Tested on wired Carplay.
ARC build 428
iOS <=27
ARC build 428
iOS <=27
This is not a feature request @Carl
This behavior is not the way iOS expects apps to handle audio (privacy concerns a.o.).
“the rule is tied to an output device becoming unavailable”
Hi @jmvdv
Thanks for confirming what build of ARC is running.
I’ve moved this back to Early Access(from Feedback > Feature Suggestions).
Did you notice this behaviour on previous ARC builds?
Yes also on older builds.
