Has anyone else noticed since the last firmware update that Roon doesn’t change the volume of the BDA-3.14 anymore? The Roon GUI works, but the volume doesn’t change and the volume LED bar display on the front panel doesn’t activate.
The only way I can get the volume to work is to use the Bryston remote control.
All other Roon functions, such as play, pause, etc., are fine.
I’ve rebooted the Bryston unit and the Roon Core.
