Cambridge Audio CXN no longer working on USB
John
Some progress… Selecting the “Disable MQA USB HID Protocol” enables USB 1.0 and I can successfully play tracks. However, USB 2.0 will still not register, appearing briefly when Roon tries to enable it before disappearing as an option.
Geoff
Hello @Geoff_Bulte,
Can you confirm the exact version of the firmware you are running on the CXN, as well as if the device is the V1 or V2 revision? I’m going to forward this info to the tech team for further investigation.
-John
John
CXN is V1, firmware is v009-a-131+a
Good luck - it would be nice to get those high frequencies back on USB 2.0 even if I can’t hear them
Geoff
Hello @Geoff_Bulte,
We’ve made another change on your account that may help get this issue fixed for you. Please reboot your Roon Core to allow this change to register. Let me know if you see any changes!
-John
Success USB 2.0 now working. Thanks for the fix. Does this mean I can upgrade the CXN firmware?
Geoff
@john
What did you adjust and can you do it for me?
I still have a USB class 2 issue with my CXN and Roipeee , mine is V1 too
The best I can get is 24/96 on Class 1 . Roon doesn’t see CXN class 2
Mike
Hello @Mike_O_Neill,
At this current moment, this “fix” can only be applied to computers running ROCK or Nucleus. We’re hoping to have a solution for users on other platforms in the near future. I will be sure to let you know when this happens!
-John
Mike
