Speaker / amplifier in question is all that you currently have in your player software + all the DSP + D/A converter + amplifier (+ speaker). Wireless through WiFi.
Especially it saves the complication of going to low level analog signal before amplifier. So essentially the amplifier is a “power DAC streamer”.
If source material is DSD, it makes full sense to send it as DSD to such system where you have a separate DSP engine specifically designed to process DSD content.
Yes, that is what DACs can use. So far I’ve not seen for example floating point R2R ladder implementations… IIRC, USB Audio Class doesn’t support floating point samples either.
Is also a complex signal presented in frequency domain with real and imaginary parts a PCM?
We could also just say that SDM is 1- or more bit PCM and get over with it. Then there’s nothing else than PCM ever. You are happy then?
To me it matters what the actual D-to-A conversion section can use.
Even sticking to integer samples means you need to requantize. Since if you add two 24-bit values, you get 25-bit result. And if you multiply two 24-bit values, you get 48-bit result.
Very happy! I’m happy tou said it, because when I said it, people said 1 bit was PDM, not PCM, and that it was fundamentally different than PCM. I hope that settles “PCM bad DSD good” kind of debates.
That PCM badness has more to do with band limiting and insufficient sampling rates. And the problem of creating PCM converters (R2R) that don’t have imaging, settling time and linearity issues.
Low bit PCM at 10+ MHz sampling rates don’t have such issues.
Non-Nyquist (heavily oversampled) systems are great, no need for anti-alias filtering or rate down-conversions.
Current audio ADC options are either down-sampled PCM (bad). Or DSD128 / DSD256.
It’s badness only if it’s audible. 44.1kHz is enough to cover audible range, and if there’s enough computing power to to do DSP at MHz frequencies, then there’s enough power to do brick wall filtering with negligible passband ripple and enough stopband attenuation with no objectionable pre-ringing. I’m sure HQPlayer’s filters are more than capable of doing that
It is pointless exercise to convert down to 44.1k or 192k and then back to 10+ MHz. While you could as well skip any rate down conversions. Just keep increasing rate at DSP steps to gain more headroom.
Most of the music I like doesn’t. Even if it did, I would opt for Red Book for all the other reasons. I just don’t want to store 7 or 8 octaves of noise. At 16x more data, WavPack would have to achieve a compression ratio of over 93% just to get to Red Book WAV size, before any savings with FLAC. I’m ok with DSD for D/A purposes and maybe as a raw archival format, but that’s about it.
Pulse Width Modulation. This is the output from a Class D input stage (Modulator) to the power transistors.
PWM is a special case of PDM where the switching frequency is fixed and all the pulses corresponding to one sample are contiguous in the digital signal. For a 50% voltage with a resolution of 8-bits, a PWM waveform will turn on for 128 clock cycles and then off for the remaining 128 cycles. With PDM and the same clock rate the signal would alternate between on and off every other cycle. The average is 50% for both waveforms, but the PDM signal switches more often. For 100% or 0% level, they are the same.
Understanding ‘more’ is a relative term here. I have gone from understanding almost nothing to slightly more than nothing.
In other words, D/A conversion uses zero-order hold. It’s not as bad as it sounds since at MHz frequencies the roll-off in the audible band is insignificant (-0.003 dB at 20kHz for DSD64) . Multi-bit SDM is handled the same way.
