Can I add Artist and genre info to a specific playlist
Hello,
I have been wondering for a while now if it is possible to make a playlist in Roon and then tag it with a specific genre? For instance throughout my collection there are quite a few holiday themed songs that are included on various box sets and/or otherwise regular recordings. If I were to create a playlist consisting of these random holiday songs would it possible to then add the “holiday” genre to that playlist so it would play if I was randomly playing songs tagged as “holiday” or “Christmas”?
Also, is possible to tag a playlist with a specific artist? So, for instance, if I were to create a Miles Davis playlist is there a way for that playlist to show up on The Miles Davis artist page along with his other recordings?
Thanks in advance for any help.
Dan
Yes, you can tag a playlist with Christmas. Just click the three dots when your in the playlist and select «add to tag»
Don’t think you can add tags that will link into the artist page
They want to apply (colloquially sometimes also called „tag“) a Roon genre to a playlist, not apply a Roon tag. This would make the playlist appear when going to the genre. I don’t think that’s possible, but your method might be an alternative (if a little less elegant)
Hi, yes you are correct. I think it would be really cool to be able to apply a Roon “genre” or “artist credit” or even “cover art” to a playlist. Seems to be doable, but not sure you can do it as of now. Thanks again.
Dan
You can open a topic in Feature Suggestions
Just did. Thanks again for your help.
D
