Can Someone do a Guide to RoonOS 3.0 on ROCK?
The Nucleus and Nucleus Plus are not upgradable, but continue to work. Likewise, a NUC that isn’t setup for UEFI will also continue to work. Unlike the original Nucleus models, a NUC can be upgraded with some changes to the BIOS and reinstalling Roon OS.
The original Nucleus and Plus are absolutely upgradeable if the BIOS is changed to UEFI. I had done this a while ago in the process of replacing the SSD. My Nucleus+ Rev A is running 3.0.
Sorry, one other question…When I do the upgrade, should I do it with or without my external USB SSD connected? Does it matter?
Yes, but you will end up with ROCK running Roon OS 3.0. It will not be recognized as as Nucleus anymore.
Disconnect the USB drive to avoid accidentally writing the image to the wrong partition.
After changing the BIOS and installing ROCK, you then need to contact Roon support to update it to Nucleus. My Nucleus+ is recognized as a Nucleus+ in the new 3.0 interface. It is fully running as a Nucleus on 3.0.
This is not possible for Roon OS 3.0. That route is no longer an option, which is why the Help Center states that Roon OS 3.0 is not available for Nucleus and Nucleus Plus.
@mjw,
Thanks for clarifying, good for others to know. I guess I was lucky I did that I did the SSD update a couple of years ago when it was still possible to do it that way. Glad I did and now have a fully updated and top performing system which is running exceptionally well since the recent performance updates to Roon.
Strange because I know a couple users that did exactly that. And they did it only a couple days ago. So what’s up with that?
I appreciate the help.
I updated the Nucleus to ROCK 3.0 but leaving it there … support request not made as its just a backup core for fun.
Hi everyone,
We’ve been following the threads about installing ROCK on older Nucleus hardware to get Roon OS 3.0, and I know many of you were hoping it would be a way onto 3.0. Unfortunately, installing ROCK on a Nucleus is not an upgrade path we support or recommend.
The install is technically possible, but the BIOS and operating system changes can leave some devices unable to boot. Nucleus+ Rev B is especially at risk. Even when the install is successful, ROCK lacks the hardware-specific configuration that Nucleus uses.
We want to be unequivocal on one point since it is of consequence for anyone weighing this install: Roon Support will not convert a ROCK install into Roon OS 3.0 for Nucleus. Please do not begin the procedure on the expectation that our team will be able to complete that conversion.
If you’ve already made the switch, please consider contacting Roon support before taking any other steps; our team can go through your options, although recovery may not be possible in every case.
Everything above is about the Roon OS 3.0 upgrade. Your Nucleus is not affected otherwise and will keep running Roon exactly as it does today.
Thanks @benjamin for a much appreciated clarification.
Are the old builds for roonos1 still available to reinstall?
Better late than never. However the irony is that less technically adept people buy Nucleus because it just works. Then we get seduced (I want to display now playing using HDMI) and decide to break the rules. With hindsight the RoonOS 3 directive that states it is unavailable for early Nucleus should have said that support is voided for any hack upgrade.
I have raised a ticket to help restore my expensive Rev B but I am doubtful. I feel I have paid dearly for my foolish endeavour.
I rather focus on functionality than on design. I repurposed an old NUB8 i5 BEH (could not update it to secure boot for safe future use) and installed Roon 3.0 from the scratch. Disabled some unused devices along with legacy boot and secure boot and ran the installation via USB installation stick. Went without an issue and I did not experience the HDMI issue some others were confronted with for the same generation of NUCs. What always amazes me, is the lack of testing that Roon does. The NUC8 series is still on their official compatibility list, but these NUCs can give serious headaches when updating to Roon OS 3.
In your situation, I would sell the Nucleus and buy a known good NUC and call it a day.
To be fair, RoonOS 3.0 was released to the Early Access group (with over 700 members) for us to kick the tyres. It’s unfortunate that any NUC8 users appear to be using the HDMI connection, so this issue did not surface until it was released to production.
Yeah, but any hardware on an official compatibility list should be tested internally for regressions
Hoping The Roonies will sort it.
I am missing Roon and want it back!
I don’t think it’s even that straightforward, unfortunately - I’m in the ea group and upgraded my NUC (NUC8i5BEH) to 3.0 when it first became available. Nothing’s been connected to the HDMI port for at least as long as I’ve been running 3.0, apart from once, to check out the display, but I’ve not suffered from the reboot/crashing issues at all.
Michael
Same question, running NUC (NUC10i5FNH) with Rock and on OS 1 (259). I do care for the RoonOS 3.0+ functionality so some guidance would be good. Even if it is just a matter of (updating BIOS and) reinstalling ROCK from scratch. If there is an article already about that, great, but I haven’t found it.
