Apologies if I’m in the wrong forum. This seems to be a crossover issue.
Problem: I am unable to copy .flac files purchased from Qobuz to the SSD storage drive on my Intel NUC with ROCK installed and running with no other problems.
Setup: Roon Core and ROCK installed on an Intel NUC 10i7FNH, 256gb RAM. 4TB WD SSD drive with maybe 500 GB in use. Disc is not partitioned. NUC connected to LAN via Ethernet direct into router. (A Google Nest mesh system, off of an Arris docsis 3.1 cable modem.)
Music purchased from Qobuz. Downloaded in .flac format in .tar compression and unzipped on my iMac. iMac accesses Roon Core via wifi. No issues accessing Roon Core with any device or endpoint, which, in addition to the iMac, currently includes a Bluesound Node 2i, 2 iPads and iPhone.
After I download and unzip the file, I try to add it to the Roon storage disc by simple drag and drop, but Console opens up automatically, and spits out error messages saying that “files do not exist.” (I would attach a screenshot, but don’t seem to have that ability while creating this post.) But I am able to move them around on my iMac and it’s various external SSD’s with no problems. I have checked permissions on the SSD, at least insofar as Finder is able to correctly analyze that, and read/write is permitted for all users.
While troubleshooting, I also tried to copy a generic .m4p file to the same drive, but when I do THAT I’m told I don’t have sufficient privileges. But, of course, only after putting my creds in. Oddly, when it requests permissions with the .m4p file it does that with Finder, asking for my normal iMac user creds, even though I am accessing ROCK and its storage as a “guest.”
This sounds like typical Apple permissions BS except for the part telling me that the .flac files don’t exist. Yes, they do. And accessing the ROCK storage through iMac for .m4p files, but as a guest for .flac files…which “don’t exist” no matter what the permissions settings are.
I disconnected the WD SSD from the NUC and connected to the iMac. Fully able to add, delete, move, any files on that drive when it’s connected to the iMac. Permissions settings are identical no matter whether I’m accessing it through the NUC or through the iMac.
Additional fact: WD SSD is formatted in MAC OS-EXTENDED. I don’t know enough about that subject to know if that could be the culprit.
